steering knockle need help asap!
Re: steering knockle need help asap!
i think he may be talking about the joint that attached the steering collum to the rack and pinion..all them i have done went on fine..slide it up on the steering collum part first and thenget the bottom to sit on its spot..you have to have the wheels in the right place as it will only go on one way
You don't mean the steering knuckle, then (your front wheel hubs attach to the steering knuckle). You mean the steering shaft coupler. It is usually a tight fit that just has to be played with to get it back on.
Henson071
09-21-2015 04:31 PM
