Steering shaft rubbing on headers
Re: Steering shaft rubbing on headers
I believe sometimes you can move the shaft to the side a bit by loosening the flange that positions the steering column on the firewall. Also remember a solution from many years ago that involved punching out the sheer pin in the upper u-joint on the shaft, allowing the shaft to be slid out slightly and lengthening it.p for more offset. Finally, a minor "ding" on the interfering header primary may be enough.
I have no idea on that one.
This thread indicates it makes more room.
http://ltxtech.com/forums/showthread...aft-*Write-Up*
