still a bit of roll when cornering + rear wagging on corner exit accel.... upgrades?
#17
Re: still a bit of roll when cornering + rear wagging on corner exit accel.... upgrades?
I carry the rubber bushings in stock..
As for the roll, bars are much more effective at roll control than are springs. Example: An autox car with 500 springs and a 35 bar rolls the same amount as one wtih 1000 springs and a 32mm bar.
You can do springs if you wish. But with normal Bilstein's it's asking for trouble (lack of damping) and you have make a wise choice on which springs you want for good handling, and there are a lot of poor choices out there. Further the car will ride harder and roll more than with a bar change alone.
Also, you haven't even tried the shock to see the change, which will be large. And tuning the car on what-if's is not smart. Get them in, see what you get and go from there. Don't assume......
#18
probably right, no sense in sinking more money into springs ... just bigger front bar and get the shocks in....
edit: i was browsing stranoparts.com and noticed that the 35mm hollow bar is actually roughly the same price as a new set of springs so i guess the bar would be the better idea.... also considering higher rate springs require higher dollar shocks anyway....may as well keep stocker springs
thanks for your help guys - i'll keep the 1LE part numbers (if/when i get them) in mind just in case i decide to go a little further..
#19
the day i put on Sam's hollow 35mm front bar on a 94Z, it was real noticeable that the car turned in harder and flatter. thanks Sam!
i was running eibach pro kit w/ konis SA already. i recently went with a Ground Control front coil over kit w/ 500# springs and 1LE rear springs from my friend. Set front ride height to about 26.75" Again, found improvement over the prokit.
![Bow](https://www.camaroz28.com/forums/images/smilies/bow.gif)
#20
well, i'd like the 1LE kit but i dont think $200+ justifies it.....
perhaps just the 35mm hollow bar
F'n1996Z28SS
08-23-2023 11:19 PM
10-31-2016 11:09 AM
