Stock Shocks?
Re: Stock Shocks?
I didn't think chevy put Koni shocks on there cars. The last owner of the car didn't mention there were after market shocks installed. I seem to find a more aftermarket parts on this car every week
Re: Stock Shocks?
Re: Stock Shocks?
Originally Posted by Camaro_Maniac63
Certain year 1LE option-package equipped Camaros came with the yellow Koni shocks that you are describing. If your car was equipped with the 1LE package from the factory, you will also be pleasantly surprised to find another adjuster on the top of the shock to adjust compression ; the bottom adjuster takes care of rebound. So you probably have the infamous, $1200/set Koni Double-Adjustable shocks but just to be sure, check and see if you have a factory 1LE car or not (I think you can tell from the VIN, but I don't know what code to look for. Maybe someone else will chime in on this). Even if it is not a factory 1LE car, and even if you don't have the adjusters on the top (meaning you would have the single-adjustable Konis), you still have damn good shocks on your car. Congratulations.
Bottom adjustor takes care of compression settings.
Upper adjustment handles rebound.
Single adjustables don't have the bottom adjustment, they have the top only, so if you have bottom adjustors they are Koni DA.
Do a web search under "koni north america". You will find the info on how to adjust the shocks.
Upper adjustment on the front requires a pin or 2.5mm allen wrench to spin a wheel with holes in it. The rear needs a white plastic ****, check your glove box or order one for $4.00. Upper rear adjustment is under the carpet, there are some cut outs in the carpet from the factory.
They are good shocks and did come OEM on 96-1999 1LE cars. You can also buy them aftermarket and bolt them on.
Z28
Re: Stock Shocks?
Originally Posted by Z28barnett
FYI,
Z28
Z28
Re: Stock Shocks?
I have never heard of a 1LE camaro before. I just bought the car 2 mounths ago just thought I was buying a regular 1997 Camaro Z28. Now that I have looked on my service parts idenifacation sticker and found the 1LE code I got on 1LE.NET and read about the 97 1LE camaros, it describes my car and the fact that only 48 1997 1LE camaros were built makes me feal special, bow down bitchs I got a 1LE. I still plan on tearing this car a part though, I didn't buy it to be a collectors Item. I wanted to replace to front shocks with some QA1 R-series.
Re: Stock Shocks?
