"strut" brace install
#17
Re: "strut" brace install
Originally Posted by robertotrevino
Im gonna try and cut the nut with a dremel tool, I dont wanna damage the shock base with the impact gun.
![Confused](https://www.camaroz28.com/forums/images/smilies/confused.gif)
#19
Originally Posted by Z95m6
There is no nut.
If i remember correctly the bolts thread into the spring mount.
On the passenger side, the two front conections are studs mounted to the spring seat, with nuts. The rear two connections are hex head bolts into the spring mount. On the passenger side, the two front connections are studs with nuts, the two rear connections are Torx head bolts.
#20
Originally Posted by Injuneer
Its a mixed bag......
#21
yeah, I was using a metric wrench... Finnally, I did it, I dremeled it out... I basically cut the nut in pieces. and that way I could take it out without damaging the studs.
Richardan15
05-30-2015 08:36 AM
