Strut mounts???where can I find them
I am getting some Drop Zone springs for my car and it already has 198k miles on it.. Where can I find some strut mounts at a good price?? I havent found any on Summit or SLP I just dont want to re-use the originals since i'm replacing the springs and will have everything apart..
I'm used to replacing strut bushings on the Volkswagens and Audi's I work on every day so I figured the Z28 would have strut bushings as well but all I found is "strut mount" if thats what I need cool.. but where is a good place to get.
Thanks, Thomas
Thanks, Thomas
strut mounts or strut bushings
Ok, but am I looking for strut mounts or strut bushings????? see there is a difference and most of the people at my local auto parts place are retards and will not know what I need unless I give them the correct terminology
It does not have struts in the front; they are mislabeled as struts because the spring mounts on the shock similar to a strut.
A front suspension with struts does not use an upper a-arm; F-Bodies have upper a-arms.
