Sub frame connector fabrication
Hello all, I was wondering if anyone had specs on ur typical subframe connectors becuz im cheap and would much rather fab up my own. Also a pic of th the underside of a 94ish with them installed would work too. And one last? I was told that the t-top and convertibles had the same reinforcement, is this true?
I know the convertible has a larger sheet metal "X" brace connecting the front floor pans. The coupe and T-top cars only have the simple straight sheet metal brace under the driveshaft tunnel. I've hammered the rear fender wells on my T-top car, and on a buddies 97 SS convertible, and there appeared to be sheet metal behind the convertible fender wells that was not present on my car.
autoxr166
09-25-2015 04:21 PM
