Sub-frame connector install ~missing bolt or not?
I just received a set of BMR tubular sub-frame connectors from Thunder Racing and was reading through the install directions (see here: http://www.bmrfabrication.com/instructions/sfc001.htm )
It says "Using the provided hardware, slide bolts through subframe connector, subframe, and control arm and install nut finger tight.
I did not receive any hardware. Do I need a longer bolt to do this install and anybody what size? Thank you
Richardan15
05-30-2015 08:36 AM
redz_02
07-24-2002 09:42 AM
