Subframe connectors pics?
Does anyone have any pictures of subframe connectors installed underneath their car? If so could you post them and what kind they are? I'm in the market for a set and I just wanted to see what they looked like on the car being that every picture of I find is just of the subframe connector itself. Thanks alot in advance for any help given.
Re: Subframe connectors pics?
BMR boxed weld ins....made a great improvement.
![](http://memimage.cardomain.net/member_images/3/web/243000-243999/243722_93_full.jpg)
![](http://memimage.cardomain.net/member_images/3/web/243000-243999/243722_94_full.jpg)
![](http://memimage.cardomain.net/member_images/3/web/243000-243999/243722_97_full.jpg)
![](http://memimage.cardomain.net/member_images/3/web/243000-243999/243722_98_full.jpg)
![](http://memimage.cardomain.net/member_images/3/web/243000-243999/243722_101_full.jpg)
![](http://memimage.cardomain.net/member_images/3/web/243000-243999/243722_102.jpg)
![](http://memimage.cardomain.net/member_images/3/web/243000-243999/243722_103_full.jpg)
![](http://memimage.cardomain.net/member_images/3/web/243000-243999/243722_96_full.jpg)
some are during installation so the welds look bad. some are after with the welds cleaned up and painted.
the last one is to show the clearance. BMR says the boxed reduce clearance by 3/4"...but with my ground effects...it didn't make a difference...the gfx are as low as the SFC.
suggestion...
right after you bolt them in...have them welded.
over time the bolt holes will elongate and will not provide the support you need.
carguyshu
01-22-2017 11:19 AM
