Suggestions on TA
Suggestions on TA
Hey all, I am tring to figure out what TA to go with. My issue is I have LTs with Duel Exhaust (X-Pipe). I was wanting to get the BMR Trak-Pak, but I don't think it will fit with my x-pipe. So I think my only option is the BMR Trans mount TA. Is there anything I might be missing, or is that my only option?? Thanks
Brad
Brad
Re: Suggestions on TA
Even the Spohn won't clear the x-pipe in the standard "X behind the transmission" fashion. I'm in the same boat and thinking about getting the Spohn torque arm for long tubes (big opening where the Y-pipe converges) and re-creating the duals.
Here's my plan... Put the X where the Y converges (between the Spohn mount and undercarriage). Replace the upper panhard rod mount with the BMR one that gives extra-clearance for exhaust. Then run both pipes down the passenger side and out the back of the car.
This way, I get the beefy torque arm, the true duals with X-pipe, and I get to send them out the back of the car and use a set of corsa tips I have sitting on the shelf.
![Big Grin](https://www.camaroz28.com/forums/images/smilies/biggrin.gif)
