suspension
Re: suspension
when u say u are replacing your suspension
do u mean you are changing shocks?
in which case u dont need to change your upper mounts
if by replacing suspension u mean your replacing all your bushings, your shocks, sway bar endlinks and maybe your springs, then yes definately change the upper shock mount while you are in there
Re: suspension
I would replace the upper spring seat/shock mounts on a 4th Gen, no matter what you are doing to the front end. The rubber rots and the shocks have been known to rip the center right out of the mount. If you are doing springs and shock, or the more advanced replacment, replace the mounts.
