suspension advice?
suspension advice?
car is / mods are
95 z28 convertible -minor bolt ons (intake, plugs, hyp PP,edl headers, flow exh.) but 383 is in the build as we speak
-lowered eibach sportlines on 19's
-LCA's, Torque arm bar, PHR, tokiko springs
my front wheels are a little cambered even after alignment
am going to buy K-member and tubular upper / lower Aarms, should i spend the extra $ to get adjustable
im also going to change swaybars front and back -will i be OK with BMRs 32mm package? or does anyone suggest anything else?
also read some other threads and decided i will change subframe connectors, being that im reading its much better for verts. but also wanna know if it is really worth changing LC relocation brackets, especially that im 2" dropped???
Re: suspension advice?
The lower control arms are adjustable in stock form. You can get the after market ones with the adjustable hemi joints in them making each joint adjustable in two places. Whats the point???
If your dropped 2", you need relocation brackets. Good SFCs are also a must for verts.
Originally Posted by slowpoke310
car is / mods are
