Suspension/Chassis and HIGH mileage
Hey everyone, got a nice board here it seems like. I just wanted to say that I have a 95 M6 z28, and its just about to roll over 150k miles. When the motor goes shot in it, i'm debating on whether to buy a different z28, or just this one and rebuild the motor, possibly go with a stroker kit. But if i keep this motor and rebuild it, how is the frame and suspension and everything going to hold up at about 200k-250k miles on the frame of the car ? And if things dont hold up, could you list some of those parts that won't?
![](https://img.photobucket.com/albums/v325/dustin2671/side2.jpg)
Re: Suspension/Chassis and HIGH mileage
My 95 is holding up fine with 146K miles. You should freshen up the suspension parts (ball joints, bushings, outer tie rods) and shocks. No signs of frame issues on mine but mine hasn't been exposed to winter time salt "treatments"!
You might want to add subframe connectors. But thats really about it. I just added em on my 130k formula. Not an outstanding difference, but it feels a little more connected.
Bushings and ball joints are the only thing that really wear out. I have 173,000 miles and I have only changed the bushings when I upgraded suspension parts. Same ball joints too.
I am putting poly bushings all around in my car. Should I put new ball joints and tie rod ends in while I'm there? Should I just replace the outer tie rod ends?
Welcome to the board
Yea i'd just leave it for now, it will hold up. Plus if you stay on here very much you'll be buying all new parts anyway
Skip meals to buy some LCA brakects and such....lol.
I also suggest getting some Subframe connectors---they do wonders for these cars. Night and Day difference....get the dimond type if you like to take fast corners--such as the SLP type
![Big Grin](https://www.camaroz28.com/forums/images/smilies/biggrin.gif)
It's good to have your tie rods and ball joints checked by a professional mechanic. They are critical parts of the suspension that don't really give you too much warning before failure.
New shocks and bushings sure wouldn't hurt if they haven't been replaced in a while.
12-01-2014 08:08 AM
