Suspension Setup Questions
I know very little about suspension systems. Long story short, I am going to put an Iron Block LQ4 in the firebird so it's going to be slightly heavier than the LS1. I want to know a good front and rear suspension setup that will allow me to both hook up and handle. I don't want to lower the car more than half an inch, if even that however.
What kind of Front / Rear Springs should I go for? Are the stock LS1 springs any decent or should I replace them?
Front/Rear Springs with KYB AGX Shocks?
What about the front/rear sway bars and LCA's?
stock springs on upgraded shocks.
Koni SA would be ideal, but the AGX might be a good budget choice.
since the front will be lower with the added weight, i would pull the rear spring isolator to level it out.
sway bars made a HUGE improvement in how my car handled. much flatter in the curves.
10-31-2016 11:09 AM
Lt1son
12-31-2014 01:35 PM
Hurin
12-13-2014 07:38 PM
