swapping out front calipers.
Location: Somewhere between a shotgun barrel, and a blood spatter on the wall.
anything in depth about this?
looks fairly simple to me...
take the caliper off as you would to change pads, only pull off the brake line... and change the caliper instead, right?
or am i missing something?
Re: swapping out front calipers.
Originally Posted by respectirocz
dont forget to bleed your brakes
i'm sure you'll rememebr once the pedal goes straight to the floor
i don't bleed the brakes after i change pads...
i just pump them a few times to uild the pressure back up... then check the fluid level... is something different?
![Confused](https://www.camaroz28.com/forums/images/smilies/confused.gif)
i just pump them a few times to uild the pressure back up... then check the fluid level... is something different?![Confused](https://www.camaroz28.com/forums/images/smilies/confused.gif)
i dont bleed after i change pads, but i do bleed after i change calipers
10-31-2016 11:09 AM
carguy0119
04-11-2016 11:11 PM
CGM2010CAMARO
04-07-2015 07:44 PM
07-04-2005 05:00 PM
