Sway bar bushings
Sway bar bushings
I'm going from a 30 mm to 32 mm front sway bar. I have new bushings and am wondering if I'll need new brackets for the larger bushing or will the stock brackets that hold the bushing around the sway bar still work? Thanks
Your stock brackets are the same part number between the 30 and 32mm... only the rubber bushing is different. I just swapped in a 32mm front 1LE swaybar this weekend and the car handles great now on my stock suspension Z28. I was surprised how big of a difference it seems to have made.
Shocks are next...
Shocks are next...
