sway bar/end links? and tie rod ?
when i replace my sway bar do i bolt down teh endlinks all the way util i used up th threads and then torque them down?
i hope u know what i mean ....
also i got teh part number for the outer tie rods......what is the number for teh inners?
no, not sure what you mean, usually you can barely get the nut started on the end links. you gotta kind of compress the bushings to get the nut on, then good and tight is sifficent. Dont break out your torque wrench for end links!
Hurin
12-13-2014 07:38 PM
