sway bars
Re: sway bars
It's my understanding that the ST bar is solid. Give Sam Strano a call at Stranoparts.com. He's an F-Body suspension expert and can help you setup your car. He offers a hollow 35mm front bar; I have one...nice piece.
Re: sway bars
i always though st made a hollow 35mm one
Re: sway bars
ST is solid 35mm. SLP (overpriced) & Sam Strano make a hollow 35. Hotchkis makes a hollow 36.
As noted correctly, too big of a bar on the rear makes it easier to lose. Generally, most run no bigger than 22hollow/21solid in the rear, and that's usually when matched to a 35mm up front, not the stock or 32 bar. Your spring rates play into this too. Call Sam up, he'll guide you down a good path.
Re: sway bars
The ST bar IS solid
and pig heavy. Stranos or Hotchkis are the hollow pick one of those.
Stanos is the best for everybody. But I got the 36mm Hotchkis for my 94 and the 99 has that pig heavy ST bar on it
![lol](https://www.camaroz28.com/forums/images/smilies/lol.gif)
![Stick Out Tongue](https://www.camaroz28.com/forums/images/smilies/tongue.gif)
Re: sway bars
I just received the hollow 35/22 mm bars from Strano Parts yesterday. Very nice pieces. As previously mentioned, give Sam, Jr. a call. He was very generous with his time and expertise regarding setting up my car.
Re: sway bars
whats the part number for a Strano 35mm Hollow Front Sway Bar? I wanna order one and just wanna make sure I'm ordering the correct one. Is it through Addco? ADD-35MM Hollow Bar? thanks.
