Sway Bars?
Sway bars work best with the rear and front working together. Most people find 35mm front and 21 or 22mm rear to work well together. The sway bar is a torsion spring, therefore they're not made out of chrome moly as that's not an ideal spring material.
A corner carving suspension and a drag racing suspension don't really mix. Corner carving calls for a stiff suspension to minimize weight transfer during cornering; drag racing wants weight transfer to the rear during launching. Years past I wanted both. I installed a set of QA1 12 way adjustable shocks on all 4 corners thinking I could dial in the suspension I wanted for that day's driving adventure. These shocks are very poor performers for corner carving. Also for corner carving you'll want a larger front sway bar; for drag racing you want want a sway bar at all.
So your sayign that KYB gas adjust shocks are worthless????
http://cgi.ebay.com/ebaymotors/KYB-A...QQcmdZViewItem
