t top conversion?
t top conversion?
I saw a add on ebay for t top coversion. Ive got a 95 z and id like to put t's in it. can this be done? I emailed the guy and he said sure its done everyday. Ive got a freind with a wrecked bird and it has t's i can get for cheap. Has anyone out there done it?
Re: t top conversion?
No "bolts" involved. The coupe roof is plastic. You cut the front of the panel off with a grinding wheel or a saw. Then there is a sheet metal structural member on each side, above the door opening that needs to be cut out. As you noted, the "t" member is already there.
Go to this website:
http://dw-zone.com/
Click on "My 94 Formula....", scroll down to "Winter 2000/2001", and click on the "install t-top" link. Excellent photos and narrative.
Go to this website:
http://dw-zone.com/
wow thanks. i would have never gotten thru that without some instructions. So would you do it again? was it worth it? I can get the whole set up out of a wrecked car for 100 bucks. Im a jack of all trades master of none do you think it was a hard job?
carguyshu
01-22-2017 11:19 AM
10-31-2016 11:09 AM
NewsBot
12-03-2014 12:30 PM
FilledWithFurySS
07-26-2002 02:00 PM
