Is there a different Spohn tq arm for 12 bolts?
I figured since the stock torque arm works on the moser 12, that a spohn torque arm should also. Bought one from a member and I cant get the damn thing onto the housing, seems like it's 1/8 inch too narrow at the end
![Confused](https://www.camaroz28.com/forums/images/smilies/confused.gif)
Yea this has two sets of holes also, but put it like this if the end with the bolt holes is 6 inches from top to bottom, the width of the housing is 6.1 inches. I cant even get it on there to use either set of bolt holes.
Yea I unbolted the piece that bolts to the housing and it is bent slightly, about 1/8-1/4 inch. Found that out earlier, a little upset, but it can be fixed.
Speeds8erM-1
07-28-2002 06:18 PM
Speeds8erM-1
07-18-2002 11:36 PM
