Are there pics/tutorials out there on how to install SLP SFC's?
Just as stated in subject I am going to get those SFC's. I want to see where they go Welded in. I have a 94Z. And is there any truth to the car having to be lifted by the wheels and not the frame, when they are installed?
![Wink](https://www.camaroz28.com/forums/images/smilies/wink.gif)
Re: Are there pics/tutorials out there on how to install SLP SFC's?
Originally Posted by 87DJP2001
The car should be on its wheels when the SFC's are welded in. Not on a frame lift.
Originally Posted by Red96Lt1
The main thing is to have the suspension loaded. I did it without a drive up lift, and I just had the front tires on ramps and the rear of the car supported by the rear end. BMR also has some good instructions. Installing SFC's doen't vary too much by brand.
Red96Lt1= Are the numbers posted in your sig accurate? It just seems that with your mods I thought those would be a bit higher.
Especially with long tubes on there, off-road pipe and CAI. I would have thought that those 3 things alone would give you at least a 30+rwhp bump? Just curious though.
F'n1996Z28SS
08-23-2023 11:19 PM
Richardan15
05-30-2015 08:36 AM
