Are these Bump Stops any good??
![Question](https://www.camaroz28.com/forums/images/icons/icon5.gif)
Hey everybody. Just got a set of universal bump stops from Energy Suspension, part number 9.9119R. They seem real small compared to the originals. Here's a pic of the part:
http://www.energysuspensionparts.com...?prod=9%2E9119
There are two of that item in the box. I know it's universal, so will it work on my car?? Or do I have to use both of them on one side?? Are the bump stops too small??
Any help would be appreciated. Thanks.
Carlos
Carlos
Re: Are these Bump Stops any good??
If those have the correct height for what you are trying to accomplish they will be a good choice. The design makes it a progressive bumpstop and most likely they are using the soft 70 or softer durometer material which is commonly used for bumpstops.
Well the car has stock suspension at the moment but will soon be upgraded to Koni SA front/rear, and Hotchkis springs. I don't really understand what you mean by correct height, and further more how would they be installed? Is it one on each side, or two on each side?? What direction are they installed and how?? I'm sorry for so many questions and even some where the answer may be obvious. I just want to get this right.
Thanks.
Carlos
Thanks.
Carlos
ford
08-03-2002 02:39 PM
Fbodfather
25
06-21-2002 04:12 PM
