thinking bout sub frame connectors...
thinking bout installing some next spring or this winter. do they really make a difference as in body flex and somewhat quite the car down alittle with rattles. classic fbody rear hatch lock rattles over bumps... plus i don't want to get dimps on the quarter panels also.
Re: thinking bout sub frame connectors...
Doing a search for subframe connectors will give you alot of useful info on this subject since it comes up about once a week.
In my opinion its the very first mod you should do to any subframed car.
I suggest UMI boxed for $139.99. Although since you car is lowered you might want to look into Hotchkis ones, they supposedly are made for lowered cars. They run around $179.99 though. Yes they will help, although you need to think about that 1LE sway bar too
-Dustin-
![Big Grin](https://www.camaroz28.com/forums/images/smilies/biggrin.gif)
-Dustin-
I used BMR round SFC "welded" for the ground clearance, boxed may go 1/2" or more below body, but is stronger... Mine is a daily driver.... ![Smilie](https://www.camaroz28.com/forums/images/smilies/smile.gif)
And yes you will feel the difference....One of the best mods I made...
Richardan15
05-30-2015 08:36 AM
kandied91z
03-03-2015 11:34 AM
