tie rod ends? Replace inner or outer?
Are the inner or outer tie rod ends usually in need of replacement? or should I replace both? (I have 115k miles and they were never replaced). I looked at the outer ones and see nothing that looks abnormal, but I figured I would replace them anyway while I do some other suspension upgrades. Any insight greatly appreciated! Thanks!
the outer usualy go bad before the inner. jack the car up. grab the tire at the 3
clock and 9:0 clock positions and move back and forth and see if there is any play. now grab at 12 and 6 and do the same. if it;s tight your pretty much ok. it;s just a simple check. are you having any issues?
![Embarrassment](https://www.camaroz28.com/forums/images/smilies/redface.gif)
10-31-2016 11:09 AM
Hurin
12-13-2014 07:38 PM
