Which tie rods do I need to replace?
Just about the only thing that hasn't been replaced in my suspension is tie rods. My steering is loose and I'm wondering if I need to replace the outer ones only or do I need to replace both inner and outer?
Thanks.
Thanks.
Re: Which tie rods do I need to replace?
What? Nobody knows?
Come guys, this is just about the only thing I HAVEN'T done on my car yet. Sounds like I have to get under the car and see what's going on myself.
![Cry](https://www.camaroz28.com/forums/images/smilies/cry.gif)
![Wink](https://www.camaroz28.com/forums/images/smilies/wink.gif)
Have you replaced the steering rack? If so then you need to replace the outers. Just grab ahold of one and twist it and see which one moves then replace accordingly. Steven
If the inners are loose or you question the integrity of the steering rack i say just replace it and for a few more bucks you can replace the outers also. Most auto parts stores can get you a steering rack and go with quality tie rods like TRW or Moog. Steven
All those parts assembled as a unit is the steering rack assembly. I am not sure if an LS1 rack is the same ..........any good parts store or dealer could tell you that. Some racks do come with the outer tie rods also. Steven
Ion, I'm pretty sure the racks aren't the same.. Did you replace the rag joint, that will always make the steering feel very sloppy. I replaced mine with a unit from Unbalanced Engineering. As far as tie rods, I believe the only aftermarket ones offered are the set from Baer, and they're pricey.
Yea, I placed an order for the eliminator. I also did a search and it looks like the LS1 rack should fit without any problems. (also looked in the parts catalog and pretty much all the parts had the same part numbers between the years)
I might try to do tie rod ends and rag joint first, then think about the rack. I don't have a lag between the steering wheel and tires, but it's just too easy to turn it. So I don't think I need a rack but just tie rods.
Thanks!
Thanks!
Your rack and pinion are fine. Just lift the front of your car up and shake each wheel left to right and check for any loose/worn out tie rods. Outer's are more common to wear first.
They are plenty of brands out there, Moog, Tread Saver etc... all are probly in stock at your closest auto part store. IF you want something pricey, look at RKSport.com
The last thing you would need is the rack. Most of the time those are replace because of leaky seals. And are not easy/fun to do.
This is what I do for a living
![Smilie](https://www.camaroz28.com/forums/images/smilies/smile.gif)
Guest
Posts: n/a
This is what I do for a living![Smilie](https://www.camaroz28.com/forums/images/smilies/smile.gif)
10-31-2016 11:09 AM
Hurin
12-13-2014 07:38 PM
