Tips for installing SFC's???
Already know about having them installed on a drive-on lift, I'm more concerned about things to watch out for?
Is there anything I should cover/move while having them welded-in? I think I read a post that said you should cover your fuel lines with something?
![Confused](https://www.camaroz28.com/forums/images/smilies/confused.gif)
Re: Tips for installing SFC's???
Its super easy to pull the carpet up along the door edges, just remove the trim panel and peel your carpet up and stick a block of wood or something in there to hold the carpet up so it doesnt burn. I had a water bottle handy to spray down the floorpan as it got hot and I dampened the carpet a little. Other than that, yeah remove the clips for the fuel lines and hold them aside while theyre welding as you tend to come pretty close to them.
I just had them installed last week. My guy only charged $105 for installing the SFC's, the rear LCA's, and checked my plug wires to make sure they were all on tight [one was a little loose].
