torque Arm
Re: torque Arm
I agree with ya on that one.
Originally Posted by RE AND CHERYL
Somethings gotta be wrong. I've seen cars with stock tourque arms running in the 10s and carying the front tires for 20 feet or so.
Re: torque Arm
Suggestion - Add a "signature" with basic info about your car, like year, model, tranny type, and any major mods. Without that info, its almost impossible to give a meaningful answer to a question like this.
Re: torque Arm
Re: torque Arm
just because it's stock doesnt mean it's bad. some are running some pretty low numbers on stock. i think low 10's is on a stock bottom end....and TA. stock heads flow pretty good if ported, stock 6-spd tranny can handle 450 tq easily enough....any way....there has to be something else in the line that's causing you to break a torque arm. it's just there to keep the axle in line. i dont think you're pushing the numbers to crumple a torque arm....but, look into a bent axle/rear, woarn bushings in the lower control arms, woarn shock mounts...that's about it...
autoxr166
09-25-2015 04:21 PM
