torque arm bolt
Re: torque arm bolt
It doesn't bolt to the transmission. It slips into a mount. Some of the clamshell bracket bolts are M8 x 1.25, others are M10 x 1.5. Configuration also depends on the transmission type (not given).
Re: torque arm bolt
But the torque arm bushing bracket has three long bolts that mount through the tranny tailshaft housing, and a short bolt that holds the inner and outer halves of the mount clamshell together. Which of those 4 bolts did you break?
