Torque Arm Question
Old 03-27-2005, 10:03 PM
NOS2006's Avatar
Torque Arm Question
Can you feel a significant difference when you put on an aftermarket torque arm? I have a '98 V6 A4 and am looking into getting one of these things...
NOS2006 is offline
Old 03-27-2005, 10:46 PM
Re: Torque Arm Question
I wouldn't think you would notice any difference. The primary function of the torque arm is to keep the driveshaft straight under heavy torque loads. The stock arm should be more than adequate with the V6, unless you're running a blower or nitrous. I've seen people run 10's with the stock torque arm. But I've also seen 12-second cars bend them and rip through the bolt holes.
The "adjustable" feature becomes necessary as the HP/torque goes up. The factory pinion angle is generally correct for "stock" power, but as power levels go up, you have to increase the (negative) pinion angle to counter the upward movement of the pinion shaft under heavy torque loads on launch.
Injuneer is offline
Old 03-27-2005, 10:49 PM
NOS2006's Avatar
Hmm, well it does something different than I was led to believe.
What would I be looking for to push my rear wheels down harder to the ground?
NOS2006 is offline
Old 03-27-2005, 11:08 PM
mrr23's Avatar
that's what it does. takes the upward rolling movement from the axle and in turn starts pushing down on the tires. and if angled correctly, also makes the driveline angle straight. but, in your case, it's money that could be spent elsewhere.
mrr23 is offline
Old 03-28-2005, 02:07 PM
If you want to increase traction by driving the wheels down toward the pavement, you need a set of LCA relocation brackets. By lowering the attachment point on the axle end of the LCA, the forward thrust of the tires on launch pushes the body end "up", forcing the axle down. Using an aftermarket LCA, with stiffer bushings will help as well, but from my experience, the relocation brackets provide the best improvement.
You might want to add info about what you have done to the engine/drivetrain, so that people can respond with solutions that reflect the power level your are running. Is your car equipped with the optional (optional on V6, standard with V8) limited slip differential?
Injuneer is offline
Old 04-04-2005, 10:17 PM
sir dyno's Avatar
Buy poly bushing for your torque arm. Poly bushing cost 17 dollars or so. You will see a noticable difference alone with poly bushing with your stock torque arm. And if you like the feel then buy an aftermarket on and it will perform much better. Like the others said post info on your car.
sir dyno is offline
Old 04-06-2005, 06:07 AM
Member
GoFast908Z's Avatar
When I put my LCA's in it knocked a solid .1 off my 1/4 mile time, with crappy tires. When I put in the TA it took another solid and consistent .1 off my time. I have not been to the track with my new tires (nitto), but i'm sure it will drop more.
The rear end feels much more planted and the shifting is faster and has a very direct feel to it, and it just responds to shifts much faster and with more power. I love mine.
GoFast908Z is offline
Old 04-11-2005, 04:07 PM
DiabloGT's Avatar
where do you buy them for $17?
thanks
DiabloGT is offline
Old 04-11-2005, 04:08 PM
DiabloGT's Avatar
does it help anymore to get adjustable LCA's or no?
DiabloGT is offline
Old 04-12-2005, 11:02 AM
sir dyno's Avatar
thanks
POLYURETHENE bushings
sir dyno is offline
Old 04-12-2005, 02:51 PM
Adjustable LCA's are of very limited value. The LCA's position the axle assembly front-to-back in the wheel wells. Changing that position does little, except when you need to gain a little more clearance for large diameter slicks. It will not measureably change pinion angle. Its going to alter the instant center very slightly. But I don't think you would notice the difference one way or the other.
Injuneer is offline
Old 04-13-2005, 03:01 PM
CreatiVe2's Avatar
injun, quick question about the relocation brackets and LCA's... would that be a decent setup for a stock ride height car like mine? and would it plant the rear of the car better or same with the relocation brackets.
CreatiVe2 is offline
Old 04-13-2005, 04:39 PM
5.0THIS's Avatar
Your torque arm will be fine, but get rid of the power-robbing 2 piece driveshaft.
5.0THIS is offline
Old 04-13-2005, 04:49 PM
NOS2006's Avatar
...and buy an $800 carbon one? I'm 17, dude... lol
NOS2006 is offline
Old 04-13-2005, 09:20 PM
Member
GoFast908Z's Avatar
2 piece?
Quick Reply: Torque Arm Question
