Torque specs(ft pd) for sphon TA bolts
Ok im still searching to find my noise/vibe problem on my car,its like a mystery problem that even "qualified" shop couldnt find it...
I want to check if the bolts of my sphon adjustable torque arm are at the good torque specs(foot/pound).
What i know:
-The 2 rear one that connect to the diff housing are rated at 90 ft/pd
-The 4 small one(8mm i think) that hold the tunnel brace or g-load brace are rated at 30 ft/pd
But what about the big one on the tunnel brace,the one that play the role of the swivel?
And the other big one that is at the end of the TA that hold the poly bushing?
I need accurate answer please because it as been 1 1/2 year that i investigate on that problem and loose bolts could be my problem.
Thank you
What i know:
Thank you
Re: Torque specs(ft pd) for sphon TA bolts
I believe that is also 30ft-lbs maybe a little less. You are suppose to be able to swivel it. In the instructions it is very vague and doesn't exactly tell you.
Wicked
07-07-2003 01:28 AM
