traction
Are you looking for a mainly drag strip setup or something that can carve corners? If looking for a strip setup, then I would consider rear lower control arms and lca relocation brackets for starters as they are cheaper mods and do a good job in the traction department. Some other things to consider would be an adjustable torque arm and adjustable shocks/struts, these will run you more in the money department though. Subframe connectors would also be a good mod to stiffen up the chassis. Finally, tires, tires, tires. No matter how many suspension mods you do, your car still won't hook unless you have a good set of tires out back to grip the pavement.
thanks for the info....i know i ask all sorts of questions about what next, but i just don't want to spend all that money right now and not gain much. with the 900 i would spend i could probably get lca's, relocation brackets, and drag radials. another quick question though. what do you guys think as far as drag radials. the only people i know that go to the strip use nitto 555's. they seem like a good price too. are they worth it...if not which ones are good traction and good life on the tread.
The Nittos would probably be your best bet, but keep in mind a drag radial is not going to have nearly the lifespan that a street tire would. Especially if you frequent the track and the burnout box.
When I was driving my car on the street I was running fri. sat. and sun. and they would last me maybe a month over 100 passes and I was going rounds every week also.....I think they work good and have descent life, The nitto's IMO are crap
Javi Fierros
06-10-2015 03:35 PM
