Trying to chase down a "clunk" sound
I have a weird clunk sound coming from the bottom of my car somewhere. When I slow down for a stop, and the tranny downshifts from 2nd to 1st, I hear a "clunk" coming from somewhere under the rear part of the car. It's not the trans mount, I had a poly one put in last year, and I just had it checked out the other day when I had my new shocks installed [it isn't the shocks, because I had the clunk before the new shocks].
Here's another thing. My driveway is at an incline. When I put my car in reverse from park, the car will actually jerk for a second and then stop. But it doesn't jerk when on a flat surface.
What could be causing this clunk? A bad torque arm? Bad TA mount? Bade driveshaft? Bad driveshaft u-joints? A loose bolt on the torque arm?
Re: Trying to chase down a "clunk" sound
crawl under the car or putit on stands and rockteh driveshaft back and forth and c if the ujoints are slacking or moving
another possibility is slack in the rear , with the back tires of the ground car in park rotatate the tires back and forth fast,if u hear a clunk when u reverse the direction of the rotation u could have some slcak in the rear.my car has some slack in the rear and i have the same symptoms
When I had a clunk comming from my car... I got fed up, and went under the car and torqued every major bolt I could find.
Turned out, my torque arm bolts (the two big ones at the back) were almost finger loose
Got some thread locker, and torqued those bishes. No more clunk
I also found some other suspension components a little undertorqued... but just slightly.
![EEK!](https://www.camaroz28.com/forums/images/smilies/eek.gif)
![Big Grin](https://www.camaroz28.com/forums/images/smilies/biggrin.gif)
autoxr166
09-25-2015 04:21 PM
Ryan Ramsaran
09-19-2015 08:43 PM
