Tubular Control Arms
I have a 2002 SS, and the suspension on it is all factory. I was wondering what kind of performance improvements I can expect out of swapping out the factory stamped steel control arms with aftermarket tubular control arms...
The rears are definitely worth it. The front is up for grabs. Personally, I see no real performance gain unless you are shedding weight and going to coilovers. Otherwise if you want to spend money go for it.
Rears are worth it!
Rears are worth it!
