tubular k-member and brake lines
Hey all, I've got a 95 Formula that I decided to install a pa-racing tubular k-member in while I have the engine out. The k-member is installed, no fitment issues, but I'm trying to get some ideas of what to do with the brake lines. I made up my own metal bracket to extend down the 2 or 3" that the stock k-member did, but it's flimsy and the tire hits it in a sharp turn. Would a stainless steel braided line a few inches longer work, and then I can just zip-tie it to the new k-member? Any help's appreciated...thanks.
Rob
Rob
Re: tubular k-member and brake lines
I would just do the zip-tie method. Or, since you have a tubular k-member, you might be able to use adel clamps which would be the best way. That's how we typically tie hoses back on aircraft.
Starting within the next month we are going to make a provision built on the k-member for the brake lines. Customers who currently have one of our k-members can purchase a bolt in bracket. Give us a call if you are interested.
Zack
Zack
carguyshu
01-22-2017 11:19 AM
