Umi panhard rod relcoation kit problem
Well for the one that dont know,my car got all the Umi stuff that you can install on a 4th gen
See here:
https://www.camaroz28.com/forums/sho...d.php?t=589291
Now the problem.The upper panhard rod that come with the relocation kit knock directly on the panhard rod itself when only pushing slightly on the trunk of the car...So you can imagine how it really knocking really hard when hitting some bumps.
Anyone got this problem and does anyone know any solution???
Ask Umi but never got an answer(thats the first time)
See here:
Is the car lowered? I assume it is? If so that would cause a problem.
I suggest a panhard bar bracket from Jegs that attaches to the drivers side and lowers the drivers side of the panhard bar. Seen in the link below-
http://www.ls1tech.com/forums/showthread.php?t=914853
