UMI Performance LCA's worth to buy?
Hello gals and guys,
I'm looking for better LCA's and a stronger Panhard rod for my 4th gen Camaro.
Here in germany this parts are hard to find, so I have looked at eBay Motors....
I have found this at ebay: 130098975817
are this parts the money worth?
(the benefit: he ships to Germany)
thanks for help
thanks for help
bmr has been nothing but junk for me, iv had the non adjustable LCAs TWICE and both sets the welds cracked.... and i know for a fact that they were installed correctly. with the PHR i had a end break off of it..... this was all on a stock 95 T/A since iv been using UMI i havent had one problem. as far as stealing a design umm i dont think so you can only envent the wheel once.
Yes, its a quality product and that is a good price. BUT those LCAs are less than ideal for handling because they have very stiff bushings which inhibits suspension movement. You might consider contacting UMI directly and seeing if they will substitute LCAs with bushings on one end and rod ends on the other like these http://www.umiperformance.com/2016?category_id=32 if you are after improved cornering. Also its not a bad idea to have them send you a tube of grease for the bushings with your order.
BMR's lca's look nothing like UMI's. Same goes for their panhard bar. and torque arm relocation kits
different sized tubing... what the control arms are contructed out of..... umi offers rod end/poly bushing combinations, while bmr offers poly/neoprene combinations..... actually go to both sites and look at the two and you will see differences
From the UMI website: These control arms are constructed of DOM mild steel tubing 1.625" OD x 0.120" wall thickness... with Energy Suspension® polyurethane bushings
From the BMR website: tubular control arms use...1-5/8" x .120 wall tubing...Both designs utilize stiff, low deflection polyurethane bushings. Rubber bushings also available for all control arms.
You do realize that 1 5/8 = 1.625, right?
