Umi Sfc
Umi Sfc
Hey guys,
Been browsing around, the UMI 3 point SFC look good. I like the dual support (on both sides) for the LCAs, and how it ties into the stock tunel brace bolts.
Does anyone have these installed, and if so, how do they like them? Would they work well with a Spohn Torque Arm (tunel mount), or not?
Thanks guys,
Igor.
Thanks guys,
Igor.
Re: Umi Sfc
I have the UMI 2-point SFC's. The mounting plates on the end of them is 1/4" steel, and I'd assume that the 3-points would use similar construction. So you'll need to verify that your tunnel crossmember bolts are long enough to pass through everything.
FWIW, UMI shows their 3-point SFCs installed along with their tunnel crossmember mounted TA, so I'm sure it wouldn't be a problem with the Spohn piece. The Spohn TA and UMI TA both look very similar in design and mounting.
Re: Umi Sfc
I Have The Three Point Sub Frame Connectors And Adjuster Tourqe Arm. The Only Problem I Had Was Clunk On Take Off And That Was My Fault I Did Not Adjust Torqe Arm Correctly Now Car Is Perfect After Working With Jerry At Umi. I Would Reccomend Them To Anyone Their Produts Are Great!
Re: Umi Sfc
Originally Posted by IgorT.455/406
Yes, the two look very much alike.
I'm sure I can make my bolts work for me, and I do really like the look of the 3pc subframes. They look they are sturdy.
Re: Umi Sfc
Well I think my final choice is:
UMI 3 point SFC
Adj. trans mounted arm
DS Loop
Question:
How does a guy adjust the torque arm (how to know what is the right angle for you)?
Thanks.
UMI 3 point SFC
DS Loop
Question:
Thanks.
Re: Umi Sfc
UMI 3 point SFC
DS Loop
Question:
Thanks.
UMI 3 point SFC
DS Loop
Question:
Thanks.
Re: Umi Sfc
