unbbalanced engineering rag joint eliminator installed
Old 09-16-2007, 07:27 PM
lethal93ta's Avatar
I finally got to put it on after getting it from a member on this board, I just took my grinder with a cut off disc on there and cut right into the rubber and through the rivets, then tapped them out with a punch and hammer, only took about 30 min to do
lethal93ta is offline
Old 09-16-2007, 09:11 PM
JimboManJones's Avatar
Well... how is it? Does the steering feel any different? Was the purchase worth it? Alittle more info would be nice!
JimboManJones is offline
Old 09-16-2007, 09:13 PM
mdacton's Avatar
Looks good
mdacton is offline
Old 09-16-2007, 09:15 PM
firebirdStud's Avatar
yeah it looks good, but how does it perform dude?
firebirdStud is offline
Old 09-16-2007, 11:16 PM
smoknta's Avatar
Any unwanted vibrations?
smoknta is offline
Old 09-16-2007, 11:25 PM
Josh'95Z28conv's Avatar
I never noticed a difference when I installed mine.
Josh'95Z28conv is offline
Old 09-17-2007, 03:40 AM
lethal93ta's Avatar
theres not engine in the car so I cant road test it, but it did take the extra play that Ihad in my steering out of there.
Old 09-17-2007, 09:52 AM
Bud M's Avatar
I couldn't detect any new vibrations when I did mine
Bud M is offline
Old 09-17-2007, 09:56 AM
Sick97SS's Avatar
Just bought one. let you know how the install goes.
Sick97SS is offline
Old 09-17-2007, 10:50 AM
NJLT1SS's Avatar
I installed one last year. Didnt notice any vibrations. Its worth it to do on a high milage car. I only have 48K on mine, did it while installing Kooks long tubes.
Nick
NJLT1SS is offline
Old 09-17-2007, 11:35 AM
TobyZ28's Avatar
Just a word of advise, when tapping out those rivets be sure that you don't collapse or expand the upper part of the steering joint If you do be sure to tap it back to normal length. Just did this on my car and the steering rack, all the play i had in the wheel is gone now!
TobyZ28 is offline
Old 09-20-2007, 01:05 PM
Sick97SS's Avatar
http://home.comcast.net/~nstama/ragjoint.htm
great upgrade!! huge difference.
Sick97SS is offline
Old 09-21-2007, 09:48 AM
chevelles101's Avatar
Do you know the dimensions of your rag joint eliminator? I was hoping to make my own. I've got access to a shop at school which has a mill and plenty of aluminum stock.
chevelles101 is offline
Old 09-21-2007, 11:12 AM
Sick97SS's Avatar
I dont know mine. But it was identicle to the old stock rubber piece.
Sick97SS is offline
Old 09-21-2007, 01:59 PM
Ok thanks
Quick Reply: unbbalanced engineering rag joint eliminator installed
