are v6 and v8 k-member the same?
well I hit a curb yesterday, it caused a hole on the sidewall of the tire about the size of an apple , the rim does not look like its bent. and the k-member is dented and dont know if its damaged yet. so just wanted to know if they are interchangeable.
TIA!
TIA!
look almost the same , only difference is the location of bolt holes and nuts for frame mounts for the engine mounts. I had both in front of me trying to decide which to cut up for a bbc swap, the 6cyl got chopped
