Vert sub-frame connectors
Re: Vert sub-frame connectors
If you are looking for subframe connectors for a 4th gen convertible, then Yes.
BMR makes a weld on tubular with extra weld points especially for the convertible... Runs $179 I think...
Kenny Brown makes the DDouble Diamond for convertibles. They are also weld on and run $279...
SLP made a bolt on that was similar in design to the BMR, but I don't think they are available anymore... They were $350 and probably aren't the best choice even if you can find them...
Good luck,
Steve
Good luck,
Steve
autoxr166
09-25-2015 04:21 PM
