vibration when braking?
i just took my car out of storage 94 z28. I took it for slow drive without heavy braking but noticed there was a shake or vibration when i applied the brakes. The brakes were perfect when i put it into storage but now after sitting for 6 months there seems to be something wrong with the brakes.
Everyone is going to say my rotors are warped, but i dont see how this can be since the breaks were perfect when i put it into storage, anyone have an ideas or suggestions to what would cause this. Also the abs light came on 5 minutes after taking it out and driving the car around.
Re: vibration when braking?
I got the abs light off now but changing the brake light fuse which was burnt out.
Also the passenger side seems to be leaking brake fluid onto the tire from somewhere.
i wanted it in general so it would get more hits.
Originally Posted by brendon444
....i wanted it in general so it would get more hits.
One other guideline you need to be aware of.... if you have a problem with the actions of a Moderator, you are supposed to take it up in a PM or e-mail, and not continue the discussion in the thread.
Fix the leak and, as Injuneer stated, make sure all the rust is off the disc's, and they're nice and shiny. If they continue to vibrate you may consider getting after market disc's and pads. The LT1's are notorious for having bad brakes. Warping is just the term used to discribe any vibration in the brakes. They don't actually warp, 99% of the time. What happens is that pad material get deposited onto the brakes under hard braking and causes a pattern of different fiction levels on the disc. The next time you step on the brakes you get a grap/release, grab/release action causing vibration. This can happen at any time, so it doesn't really matter if it was perfect yesterday or not.
whitehooptie
07-12-2015 06:10 PM
