We need a FAQ on the Suspension Thread...
I am constantly seeing people asking the same questions.
We need to write up what is available for every aspect of suspension, where to get it, and a general consensus of the product.
For example...everyone in the country says that bilsteins are the best spring/shock combo...do a write up...and a install write up wouldnt hurt...
Just a suggestion...
The reason I mention it is simple. Im in the market, and have been for about 6 months, in the process of buying an entire suspension kit for my 4th Gen...however..im always searchin and searchin, and when i dont find a thread, I ask. I do extensive research before making a purchase just to make sure it fits with my set up...
Re: We need a FAQ on the Suspension Thread...
both front upper control arms
both front lower control arms,
front sway bar
front sway bar
rear sway bar
rear sway bar
panhard bar bushings,
rear lower control arm
torque arm mount,
tie rod end boots.
here's a good list of things that we can start on.
front sway bar
front sway bar
rear sway bar
rear sway bar
torque arm mount,
tie rod end boots.
