What are the advantages (if any) of adj. vs. non-adj. panhard rods???
I was wondering what the advantages of an adjustable panhard bar were compared to a non adjustable one? My car will be DD as well as a track car (1/4 mile specific) so will there be any advantages of running the adjustable one? If not, i still would like to know the overall advantages of the adjustable ones.
Brandon
Brandon
Re: What are the advantages (if any) of adj. vs. non-adj. panhard rods???
If you're only talking about adjusting the PHB for length, that lets you center the axle better, and re-center it if you change your rear ride height for any reason. That *might* let you fit one size wider tire without rubbing.
Other PHB adjustments are possible, but they represent a pretty hard-core cornering/handling mod that has only recently started to show up outside of stock car/circle track racing use. Check with Unbalanced Engineering.
Norm
Norm
