What do I need to install a front swaybar?
Ok, so I just got my 1LE front swaybar today. What all do I need to get it installed? I know I need 21mm bushings and endlinks. Anything else?
Are these parts numbers correct and still valid?
1LE Front 32 mm Stabilizer Bar Insulator (GM p/n 10288551) $7.66 2-req for the front. [These are the durometer ones right?]
1LE Stabilizer Bar Endlinks (GM p/n 10221779) $7.05 2-req for the front.
Re: What do I need to install a front swaybar?
Nothing else needed.
The numbers are still good.
"Durometer" is the measure of hardness of the bushing "[These are the durometer ones right?]". Not sure if those are extra hard, but they are the only ones GM has available.
Let me know how that things ride with the new Sway, I need one and new shocks, its getting rediculous ridding in a car that handles like a 77 Coupe Deville.
You ever hang out or cruise anywhere? I am stuck with a very open weekend.
-Dustin-
-Dustin-
I'm usually out in Boardman on the weekends [if the weathers nice]. Chili's in Boardman [by the mall] always has a cruise on Saturday from 6-8. And they are always packed with cars.
I just bought a 1LE front sway bar. I was wondering what bushings and end links are even availabe for this? I will probably go with GM ones, but are they poly or rubber?
Do the end links come one total end link per package?
-Dustin-
-Dustin-
I just went to autozone to get a set of polyurethane endlinks, two per package. They have different ones so ask which one is right. You can get either polyurethane bushings, or do what I did. I went to www.slponline.com and under their 93-97 Firehawk, then clearance, page 3. I got the durometer bushings.
![Smilie](https://www.camaroz28.com/forums/images/smilies/smile.gif)
I got the durometer ones because I didn't want any squeaks. They're just harder rubber, like a step between rubber and poly. You will be fine with poly.
Ok, I see, I might still get them, I'll check out how much everything is at Autozone first, no matter how much I dislike the place.
How did you like your 1LE when you put it on? Noticeable improvement?
-Dustin-
-Dustin-
I still have to install it
I'm waiting until I get a bunch of other things to install along with it [new tires, tranny mount, panhard bar, rear swaybar bushings].
![Embarrassment](https://www.camaroz28.com/forums/images/smilies/redface.gif)
Man get it on there. When are you putting this stuff on? I can give some insight to that stuff, since I've done them already. If you need an extra hand let me know. With my G/F living in Cleveland the weeknights are boring.
-Dustin-
![Cry](https://www.camaroz28.com/forums/images/smilies/cry.gif)
-Dustin-
12-04-2014 11:56 AM
Wilson
07-21-2002 05:08 PM
