What do you suggest I do first?
I have an '82 Z28 with a 350 and a 671 Weiand blower. It is around 600hp. I just bought the car and the guy who built it made it mostly to be a show car. He got the engine and tranny done, and put in a Trans Am GTA rear end. He intended to tub it, but never did so he never even put sub frame connectors on it. It is a T-Top car and I don't want to twist the frame up, so I want to reinforce the car. Where should I start? Sub frame connectors? My insurance company told me they wouldn't insure it if I put a roll cage in it. I know that would help the stiffness, but that may not be an option. Any advice is appreciated!
Ben
Ben
Re: What do you suggest I do first?
I would definitely suggest the subframe connectors, they are not very expensive and they make a big difference in added chassis strength. They made a big difference for my car and it puts out nowhere near the numbers yours does.
definately some subframes...
and maybe do some research with your insur company as to why the won't insure it? sounds kindda lame. a cage is street legal as far as i know.
and anyway...how would they know? put a 4 point in
![Confused](https://www.camaroz28.com/forums/images/smilies/confused.gif)
This is really tough for me since my car has T-tops, and does not have the structural integrity of a solid roof car. I need to keep the cage out and still get stiffness.
your insurance company sucks
but yea, if you want structural integrity and you cant put a cage, go with subframes (if you can get those double diamond things that'd be great) a strut tower brace and a wonder bar
there are also those 4 point cages that are low profile so its easy to get in and out of the car, you could try for one of those and try and hide it
I believe double diamods are the sfc's that connect to the tunnel also. MUCH more connection to the other side and better than just running "tubes" down each side. They can also be further connected via tunnel brace.
SLP has them, but not for the 82. You can probably have a set welded up custom for ya if you can't find them. These would be great for a high hp application like yours.
here's a pic of the SLP's.
![](http://aycu02.webshots.com/image/5401/2003056156981169206_rs.jpg)
