What are the pro's and con's of different size wheel front to rear?
What are the pro's and con's of different size wheel front to rear like 17's up front and 18's rear? Also will 18x10.5's fit all around on a 02 Z28?
Re: What are the pro's and con's of different size wheel front to rear?
I would get the same size all the way around. I had 17's in the fronts 18's in the rear for a while. i got rid of them because i hated the fact that i couldn't rotate the tires unless i had the tires removed from the rims. Since almost all 17&18 inch tires for our cars can only spin one direction you have to get the tire switched on the rim to rotate the tires.
12-04-2014 11:56 AM
