what wrong with my car?
Old 06-11-2007, 01:39 PM
DonutMachine's Avatar
98 z28, on the highway my steering wheel shakes, but the car drives straight I don't need a wheel alignment. I just got some PZero rosso tires, they were balanced.
DonutMachine is offline
Old 06-11-2007, 01:52 PM
n2ceptor's Avatar
Unbalanced tires, Warped wheel, suspension part bent/worn???? How old are the shocks??
Rack and pinion worn??? Could be 1 thing or mutiple things....
n2ceptor is offline
Old 06-11-2007, 02:45 PM
ConElite's Avatar
Could be the tires breaking in.
ConElite is offline
Old 06-11-2007, 03:25 PM
new c6 rims
Old 06-11-2007, 05:19 PM
2000GTP's Avatar
I would do a couple simple checks, confirm good tire pressures on all the tires and also make sure all the wheel weights are in place. If you feel everything is in order and nothing suspension/chassis wise is worn out or damaged, then I would call the shop that did the mount and balance. There could always be a slight chance that the tires were not balanced correctly.
2000GTP is offline
Old 06-11-2007, 05:27 PM
i do have a replaced rearend, previous owner
Old 06-11-2007, 06:27 PM
Pyrodawg's Avatar
wheel bearings/ tie rod ends
Pyrodawg is offline
Old 06-11-2007, 07:17 PM
STAYBG87Z's Avatar
rotate the tires,if the shake goes to the rear than you know it has something to do with the rims or tires.could have a bad tire!it happens
STAYBG87Z is offline
Old 06-12-2007, 10:23 AM
i'm going to take a drive with the cam, so you can get a more in depth view
Old 06-13-2007, 03:10 AM
Style's Avatar
not likely. If you just put on tires and now the steering wheel shakes, there is your problem.
Style is offline
Old 06-15-2007, 10:15 PM
never drove it with any other tires on it
Old 06-17-2007, 09:19 PM
redcamaroz28's Avatar
Sounds like tie rods. If it's high mileage it could also be A-arm bushings.
redcamaroz28 is offline
Old 06-17-2007, 09:27 PM
it's got an intermediate roll, kinda like a musical beat
Old 06-17-2007, 09:30 PM
my lower control arm is crushed!
Old 06-17-2007, 09:49 PM
Angelis83LT's Avatar
your lower control arm is crushed?????? well.. I can only think of one way THAT can happen without hitting something major that you would definitely feel.. and that is if whoever was doing your tires jacked it up wrong... or while up it slipped and landed on the Control arm.
Angelis83LT is offline
Quick Reply: what wrong with my car?
