what are your koni shocks adjusted to?
So, just curious, what settings are you running your shocks at?
I will have the 4th gens all the way around, and I have a dana 60 out back that will be installed shortly. I will be driving it on the street 99 percent of the time. So, where is the best starting point to work from?
I will probably have the stock springs for now. I might get some advanced ones that are new to help fix the passenger *** sag.
So, advice, suggestions?
Cody
Cody
Starter point for stock spring instructions(directly from Sam Stranos himself):
Set fronts all the way to full stiff (+) then back off 4-5 full sweeps of the adjuster across that slot.
Rears. Set full soft, then up 1/4-1/2 turn.
Then have fun and play with the adjustement to see what you like most.
Bigfatrat
Parts Wanted
10-16-2015 04:48 PM
