Whats the most likely source of front end noise?
Squeak, that is. I know it isn't the sway bar because it has grease fittings on it and I just greased it. About all that leaves is ball joints and A-arm bushings. 87K mi. now and I replaced the springs and shocks at about 85K. Come to think of it, I wonder if it could be the sway bar end links, I changed them out to poly ones when I put in the bigger sway bar?
10-31-2016 11:09 AM
